The Creality CFS Desiccant Holder is crafted to enhance filament storage by efficiently housing desiccant beads while fitting seamlessly into the filament separation slot of the CFS. Its sleek and efficient design is perfect for reducing humidity, thereby improving print quality.
NB.
(model looks solid until you slice it,
YOU can adjust hole size by lessening or increasing sparse infill percantage)
PRINT AT 50% SPEED FOR NEATER OVERHANGS.
this model is less likely to be exposed to room moisture when you open your machine as it sits between the filament spools as apposed to the opened front and rear printed desiccant bead holder/trays thus prolonging your silica bead gels while giving maximum protection to your direct spools and filament
IF YOU STRUGGLE WITH PRINT FAILURES DUE TO MOISTURE,DRY YOUR FILAMENTS FIRST WITH A DRYER,PRINT THESE WHILST DRYING,TOP THEM UP WITH SILICA AND INSTALL FILAMENT WITH CREALITY CFS DESICCANT HOLDER AT SAME TIME FOR OPTIMAL DRYING AND MOISTURE CONTROL OF CFS UNIT
Model can be found on CrealityCloud (downloads free)
Creality Cloud -Creality cfs desiccant holder (for filament sepera… From SCULPTURED_REALITIES 3D Printer Files | 3MF File | Creality cfs desiccant holder (for filament seperation slot) | Creality Cloud
This model was a simple 15minute design using cubes and boolean on Blender, Its a quick under 2 hour print.
It allows you to interact with it be increasing or decreasing sparse infill to get smaller or bigger holes in the desiccant holder.
