CREALITY ENDER 3V3: HELP
Please help me fix my Ender 3v3 so I can use it again. I had been using it for a little while now and noticed a clog in it. It started as a minor fix but now it’s gotten a lot bigger than the last time it happened to me.
In the process of trying to get the top of the print head off the wires came loss. How can I fix it and how much will it cost to replace and repair?
I’ve tried to look up the serial numbers on the machine but none of them seem to be working.
New hotend assembly if the wires are broken, should find one on Amazon or Aliexpress.
Oh dear :pensive: As @Bonfireman says if the wires are broken it will mean a new hotend assembly.
I had a similar problem about a month ago and had to replace the nozzle, heater and CL Touch. It’s not a massive job to fix it but can be a bit fiddly if you have sausage fingers like mine! Cost-wise, it’s not too expensive but just annoying. I notice in your picture that there is a burn mark on the CL Touch connector. Hope you don’t have to buy a new circuit board as well!
Anway, hope you get it fixed soon :+1:
Yea I was told I might have to buy a new circuit board for it. It’s not just the nozzle that got stuck the whole head was a pain to get off because of the amount of goop it left from the last failure.
Is there a certain type of circuit board that I should be recommended to as if I had to replace mine with a new one?
This looks like it might be the one, just need to check version number also on Amazon for a few more pennies
I’m kind of curious how that leak happened as the new Enders have a unicorn nozzle system…? :thinking:
Hey you all it’s me Cameron, just wanted to inform everyone that I finally received my ordered part for my 3d printer. I should be ordering the hotend and probably the heat sink ass well. I will make another post when they arrive. As for when the whole machine is back together.
Hi i have problem i bought it today and i printed few things than i just checked bed mesh and range is 1.3xxxx than i see my x axis isnt horizonal i tried to fix it and seens better but my range is 2.28xxxxx
When i hold beds right front corner and shake it i am feeling and hearing it little space what can i do for it
