My 10w Falcon works fine if I use pass-through mode, but creates a double image on all other modes, using LaserGrbl.
I have cleaned everywhere, checked screws, checked that it is square - all seem okay. Because the engraver works okay with pass-through (but not the others) I wonder if it is some setting in Lightburn? I have tried different speeds and different resolutions, but that makes no difference.
I have checked and as far as I can see the configuration is as per the pdf guidance.
Does anyone have any ideas?
Thanks
Well - no comments BUT. I switched off “Unidirectional Engraving” under “Raster Import” and the engraving worked fine. I suspect that the head is not firing to precisely the same position - 1-2 millimetres off on the Y-axis, so on the return it’s not pointing to the right place. I’ll give some more thought to this, but at least I have a workaround.
