Hi everyone,
I have a Creality Hi printer that has been sitting unused for a few months. When I power it on, I get error BM0111 (Nozzle connection abnormal) immediately. The screen loads very slowly before showing the error, the bed doesn’t move, and no fans spin.
Here is what I have checked:
No blue LED on the hotend circuit board even with only the main cable connected
The CFS (multi-spool unit) also receives no power from its proprietary port
All cables and connectors disconnected and reconnected carefully
CFS disconnected entirely — no change on the error
Mainboard looks clean, no burn marks, no cold solder joints visible
Power supply green LED is on (24V OK)
Mainboard blue LEDs are on and blinking normally
USB port delivers power normally
Everything seems fine visually but both the hotend board and the CFS receive no power. I have no multimeter available.
Has anyone solved this exact issue? Could it be the toolhead cable or a specific component on the mainboard?
Thanks a lot
You already did quite some investigations, best shot would be to find a multimeter somewhere to check if power is delivered to the hot-end board or CFS.
I doubt it will be the cables, since then you would have 2 damaged cables or connectors. Is there damage visible on the cables?
Hi Ben,
Thanks for your reply!
No visible damage on the cables. Everything looks clean visually.
The reason both hotend board and CFS have no power could also be that the firmware cuts power to both ports when BM0111 is triggered at startup — is that possible on the Creality Hi?
I will try to get a multimeter tomorrow to test voltage on the hotend cable directly at the board connector.
Hi! I’m facing the same problem! My Creality hi is still under warranty, and they sent me a nozzle cable and a new hotend board, but unfortunately, it didn’t work. I’m still having the same problem."
Did you find the solution or the problem?
Any word on this one? Same issue here. I am not sure how to diagnose if it is the main board or the hot end board.
Might anyone with a working machine want to tell us which pins to expect the 24vdc on?
They sent me a new mainboard. After that the machine works perfectly.
