creality HI EXTRUDER FAN
My model appeared to be printing well on the first layer however after leaving it to print it pulled off the bed and wrapped around the hot end extruder piling up oodles of filament inside the extruder so to remove it I heated tithe nozzle and try to gently work out the excess filament which was quite a gob while doing so the filament adhered to the rubber fan scoop on the right side and the nozzle cover So now I get a error message And printing stops and fails The error message indicates problem with the extruder Filament flows through it nicely all the self check list complete and OK It appears to be fine until I start a print takes about 5 minutes then stops. In short I need to replace the fan on the right side and a nozzle cover Is this doable does anybody know how I can obtain these parts
This looks like the one matching my HI:
Creality Hi - Part Cooling Fan – MakerParts 3D Creality Hi - Part Cooling Fan – MakerParts 3D
