Hello,
I have a Creality Hi that I’ve been using since January 2026.
I’ve just replaced the hotend block kit, and the installation went smoothly, except when I turn the machine back on.
I get an error saying it cannot perform the calibration because there was filament in the extruder.
So I disassembled the extruder, but there was no filament stuck inside.
I reassembled everything, but the same issue persists. I then performed a factory reset.
However, the problem still appears right after selecting the language: the calibration won’t start because the printer thinks there is filament in the extruder.
I tested the extruder’s filament entry with a small piece of filament, and the blue light turns on and off when I insert or remove it (so the filament sensor seems to be working).
Thank you for your help.
