Creality Hi gives fault XS3001
First:
When the printer tried to extrude, the motor made a ticking sound, but didn’t extrude. I checked the connection on the extruder motherboard, there I found out that de motor connection was bad en when I moved it, there was a little spark, so I ordered a new extruder board.
After installing the new extruder board:
The printer still doesn’t extrude and now gives error XS2001. I also tried reïnstalling the firmware. So I ordered a new stepper motor, maybe the old one was shorted due to the spark.
After installing the new stepper motor it gives code XS3001.
The rest of the motherboard still function.
Any idea, what I can try next?
Hi @Lennert159 ! Sorry that you’re having problems with your printer. This error has no specific cause and solution. I would check the Creality Wiki page for your printer to check if there are some tips: Creality Hi & Creality Hi Combo 3D Printer User Guide | Creality Wiki
If you cannot find solution you can try to contact with the creality support. They can check it with you and find possible cause: Creality Aftersales
Hope you’ll find a solution! Best regards.
