Creality Hi issue
3 month old Creality Hi. Starting getting filament jams. Multiple times. Took the extruder apart and cleaned it out. Now, after a reset, I keeps banging into the right side (x axis) and can’t seems to figure out where it is in the x axis. Any thoughts???
If you can give more info about your setup, it will be easier to help. Some crucial infos like below;
  • Are you using CFS? or spool?
  • Did you try different filaments?
  • Whats your filament profile settings?
I have been using Hi for about 3-4 months and have never had a jam or clog issue.
Verifique a lamina do cortador de filamento. ou ela foi montada ao contrário ou esta ausente.
