I’m having a major issue with the Hi and the Z-homing. When I try to start a print, which initiates the homing procedure, the Z-axis starts by raising itself completely, does the triple alignment, then drops to roughly 10mm from the bed. All is well until this point.
When the printer does the next stage of the Z-homing, which is when it lowers the nozzle to the build plate, it doesn’t stop. It’s pushing so hard that it’s pushing the X-gantry into an angle, side-to-side and front-to-back. The belt also starts skipping at this point, and the only way to stop it is to power off the printer.
The problem started when I had a cutter issue (the magnet in the extruder body came out). I did the fix on the extruder, put it all back together, then the Z-homing issue presented itself. I checked all PCB connections and all was good, but I did find that I had pulled the wires from the filament cutter sensor PCB, causing 2 of the 3 wires to touch. I did some searches and some people said that they just removed those wires. I tried that, but the problem persists.
Any suggestions?
