After the print has finished but before the extruder head performs the final wipe action. the extruder slightly scraps the top ot the finished product. Is there a final routine that I can add in order to eliminate the scapping?
Yes, you can modify anything you want that your printer does before and after the print starts or finishes, you need to search what g code command you need to add or remplace to do what ever you want
“scraping” the top of the finished product… did you by acident activated “ironing” in Creality Print? You can find ironing under the tab Quality…
Scraping the top of an object is not something to do on purpose…
