Creality K1 Max printer after I updated the software, I started having problems.
I have a problem after I updated the software. The print head does not want to move to the end of the axes. For example, its surface is 300x300, so it only moves in the 75x75 area and does not move to the rest of the area. It only prints in this area. When I try to move it to the rest of the surface, it tells me that it has reached its end, but it comes out in the center of the surface. What problem could it be with a certain sensor? Or a certain motor? Because I have no idea what the problem is. I would appreciate help.
Try restoring to factory settings and see if this fixes your issues
If you had root access set before your update and you didn’t do a restore to factory settings before updating, this will cause issues after the update.
