Creality K2 Pro extruder motor does not activate, Support not helping
I’ve called and spoken to support….
Related to this post K2 extruder motor not working anymore - #21 by arizonan
Following their advice I put together a Youtube video for this along with screenshots and a detailed explanation of the issue and emailed cs@creality.com waited a week and am now getting the run around…
Not sure what to do here I explained in my initial email that I’ve spent like 20 hours over the course of a week dis assembling the extruder reinstalling firmware multiple times rolling firmware back. Re calibrating after fresh boots fresh installs powered down the device dozens of times completely taken off the CFS to simplify the issue.
I’ve followed all the steps someone should follow when doing this and have had multiple 3d printers over the past decade and that this looks like a low level software issue that I can’t get to or some hardware issue either with the board or cable going to the extruder….
Thank you for reaching out to Creality Customer Support
The response they give 7 days later is this:
We’re sorry to hear about the issue you’re experiencing with your printer, regarding the issue on the printer can you try to check the following
  • Check the extruder gear and filament: Look for slippage of the extruder gear, filament knotting, or poor contact between the gear and filament. Clean the extruder gear and ensure sufficient contact between the filament and gear.
  • Check filament condition: If the filament is ground or damaged during extrusion, cut off the damaged part and reload.
  • Check if the hot end is clogged: Clean the blockage in the hot end according to the clogging handling solution, ensuring the filament can pass through smoothly.
  • Check the PTFE tube: Confirm that the PTFE tube in the filament path is not deformed or blocked, avoiding excessive feeding resistance.
  • Reinitiate the feeding operation: After troubleshooting, perform the feeding operation again to ensure the filament can smoothly enter the extruder.
If the issue still persists after this steps, please fill free to reach back for further assistance
I’m thinking what is going on? This was a Christmas present and it has turned into a huge headache. Family members and co workers have asked if I’m printing anything new with the gift and I honestly don’t like talking about it anymore. It worked perfect for about a week and now I have it sitting in the corner in a box. Tried taking it to Bestbuy to return for either another Pro or upgrade to Plus with no luck because its past their 14 day return policy…. Now last resort I’m dealing with what looks like a bot responding to my emails. Sorry just want to get a post out here about it and maybe Creality sees it and actually does something about this. I’ve already spent countless hours trying to resolve the issue. I just want a working 3d printer….
こんにちは。お気持ちお察しします。
プリンター初心者の私が言える事は、サポートの遅い返信と質問に答え、辛抱強く返信を待つことだと思います。
私も消耗品のエアーフィルターが日本の公式サイトでは販売されていないのでどうしたらいいか尋ねたら、
サポートの要求は現状の写真(問題)と注文書・シリアルナンバーでした。
使用時間519hでメンテナンスサインが出て交換したいだけなんですが・・・。
サポートとのメールは非常に遅いです。それに慣れました。
最初のエラーの時はチャットを利用して(順番が来るまで辛抱強く待ちました)その日のうちに処理が出来交換部品が届きました。
色々な国からエラーの対応に追われているのだと想像してます。
この様なフォーラムにもCrealtyスタッフが常駐しエラーのフォローをしてくれると良いと思うのですが・・。
サポートと連絡を取りプリンターが使える事を願っています。
Update:
Support contacted me and I’m being sent either a replacement or replacement parts. Hoping for this to work, I’ll update this when I receive the shipment.
Got an update they sent me a new extruder motor today with cables. I followed a youtube video and only replaced the motor and ITS WORKING NOW!!!
So it was the extruder motor the whole time just did a test print and we are good to go. It was a headache at first dealing with it then the initial support responses weren’t great but it all worked out in the end. Thankfully I only had to spend about an hour replacing the motor and resetting everything just to be sure. Thanks again if anyone has similar issues it may be the extruder motor.
