Other than scanning owl figurines, I’ve been having a hard time getting my scanner to properly pick up the surfaces I want to scan.
Most of the parts I’ve been working with are black or black and glossy, which I know is already difficult. I was able to get a decent scan of a section of my car body using the Texture setting along with dry shampoo to reduce glare.
The bigger issue came when I tried scanning a black interior part—the gauge cluster cowl. The exposed side is matte black and fairly featureless, so I expected it to be difficult. The inner side, however, has plenty of ribs, molded structure, and mounting brackets, but it’s still somewhat glossy.
Even after using dry shampoo and switching settings, the scanner would not track or build a model at all. It essentially wouldn’t scan the part until I added tracking marker stickers.
Once I applied markers, it started working much better, but it still struggled to capture finer details like the plastic ribbing and small mounting points.
So my question is: is it normal to need a heavy amount of marker stickers for parts like this, or am I missing something in my setup or workflow? It feels like I’d need to cover everything in markers just to get consistent results.
I’ve also ordered actual 3D scanning spray in hopes that it improves tracking and surface capture. Any beginner tips for scanning black automotive interior parts would be greatly appreciated.
Did you scan it in broad daylight, maybe even with the sun shining on the scan? Maybe try a more shady place in this case.
How is the exposure in the small preview picture on the top right? Have you tried to adjust the exposure manually?
Hey Ryan
I feel your pain, scanning featureless, matte black, and glossy automotive plastics is pretty much the ultimate trial by fire for any 3D scanner, so don’t beat yourself up at all—what you are experiencing is totally normal for a part like a gauge cluster cowl.
When you have a surface that is both dark (absorbing the scanner’s light) and lacks geometric distinctiveness (like the smooth, flat face of a cowl), the software completely loses its reference points and fails to track.
Here is a solid game plan and some workflow tips to get that Otter Lite tracking smoothly on your interior parts:
1. Geometry vs. Texture Tracking
The scanner needs a way to anchor itself in space.
The Smooth Face: For the featureless matte black side, the scanner has zero geometric landmarks to look at. You absolutely need to rely on tracking markers here. It’s not a failure of the hardware; it’s just the nature of scanning flat, uniform surfaces.
The Ribbed Side: The inner side has great geometry (the ribs and brackets), but the glossiness is reflecting the light away, blinding the sensors.
2. Upgrading Your Aerosol Game
You mentioned using dry shampoo, which is a great MacGyver fix for reducing glare, but it often goes on unevenly, can clump in tight corners, and doesn’t always provide the bright, uniform, diffuse white surface that a scanner’s cameras crave.
Your instinct to order dedicated 3D scanning spray (like AESUB or similar vanishing sprays) is spot on.
Why it matters: Real scanning spray leaves a microscopic, completely matte, dull white dust layer that acts like a projector screen for the scanner. It turns a “hard-to-scan” black object into an “easy-to-scan” white object. Once your spray arrives, you’ll likely find you need far fewer marker stickers on the ribbed side because the scanner will finally be able to actually “see” the shadows and highlights of the structural details.
3. Smart Marker Placement (Don’t Overdo It)
You don’t need to completely plaster the part in stickers. The software only needs to see a minimum cluster of markers (usually 3 to 5) in its field of view at any given millisecond to maintain its position.
The Strategy: Space them out irregularly. Don’t put them in a perfect straight line or an even grid, as the software can get confused about which marker is which. Scatter them across the featureless flat sections about 2 to 3 inches apart.
The Frame Trick: If you don’t want to stick markers all over a delicate part, place the part on a piece of cardboard or a scanning mat that is already covered in markers. The scanner can track the background mat while capturing the geometry of the part sitting on top of it.
4. Check Your Lighting and Exposure
Because you are scanning automotive parts, environmental lighting plays a massive role.
Ensure you aren’t scanning in direct sunlight or under heavy, localized overhead ambient light, which can easily overpower the scanner’s projection. Move to a shaded, neutrally lit room if possible.
Keep an eye on the small preview window in your scanning software. Manually adjust the exposure slider. For black parts (even with spray/shampoo), you often need to crank the exposure up slightly higher than the default settings until the part shows up clearly in the preview without looking completely blown out or entirely dark.
Once your dedicated scanning spray arrives, give it a light, even coat, pop a few scattered markers on the completely flat face, and you should see a night-and-day difference in how it captures those fine mounting tabs and ribs!
let me know how you make out
Mac486
