I take it the V5 won’t play nice with any previous versions (no parallel installation)?
I honestly don’t know how that would work so I’ll put it on a separate computer to be safe…
Arrived just when I was about to switch to orca. Looks promising. Especially the Adaptive Layer Thickness. Unfortunately I cannot figure out how to invoke it. I cannot find the corresponding menu option. Any ideas?
Hi Olof, the Ender-3 V3 SE has not been updated to Creality Cloud yet, the software team will continue to update it.
Hi Gary, I have communicated with the CP team, and they said that if it is convenient, please provide us with the dmp file and they will have a check. You can send it to me via private message or email.
Hi 4everanns, the CP team has updated v5 and fixed some bugs. You can use the latest version.
Hi Manos, the CP team has updated v5 and fixed some bugs. You can use the latest version.
Hi William, about the gcode generated by 3v3 cannot run normally issue, if it is convenient, please provide the gcode and stl files. The software team would like to learn more about this problem and try to fix it. You can email or private message me.
Regard to the new version manual, the team said it will take some time because there is a lot of work to be done, but this requirement has been planned
Hi Philip. The current new version has solved this problem.
May I ask which version you are using? I can give feedback to the software team.
I have established a chat room dedicated to discussing CrealityPrint v5.
Everyone could join the chat room and communicate freely. If there are any new progress or news, I will synchronize it with everyone in this room. I will also invite relevant personnel from the software team to join the chat room later to answer the question.
Where would I find such a file? i have searched but not found anything.
I done a search but cannot find it and your Chinese text does not help so much.
does that help path below in English
AppData is a hidden folder if you type in search or run %APPDATA% it will take you to the folder
That type of file isn’t authorised to post here…hmmm
Creality_PrintV5.0.0.8636 Release
There was a new parameter download available this morning which I installed. The version number was less than what I already had (1.2.1) configured. Anyway, I now have the Led Switch and Back Fan.
Hello Optimus link dosnt work can you send me other link
Try this link:
File download is at the bottom of the page…
Thank you
