Creality Print 5.1 ... Buggy and Lacks Features -- R&D please use Orca!
@CREALITY I’ve used Cura for a year then the prior 1.5yrs was using Orca (with Artillery & Creality K1max)… just got the K2 Plus so I decided to try CP 5.1 since it looked like it was based on Bambu Studio and would have the best integration with the K2.
I like it overall but its WAY too buggy (doesnt handle per-object printing properly, crashes/hangs, etc) and it is missing features we need.
I suggest having CP’s core code use Orca even if you keep the custom CP UI you have now. This way we get modern features, enhancements, and far fewer bugs.
Examples of missing features…
  1. Arrange Object print order in list
  2. very few Filament Color options when setting colors for the CMS so they do not match the slicer
  3. Filament Colors do not sync with the CMS (Device screen) - need to set both separately, manually. really annoying.
  4. Select Filament Color to use with Print Calibrate function… it always uses the first color printed with so it does not calibrate flow with any other. Ideally we could calibrate all of them prior to printing.
  5. KAMP type dynamic bed mesh so it only needs to do the bed mesh for the areas its printing on.
  6. User ability to arrange web UI to liking - move sections around
Orcaslicer now has a K2 Plus profile if you want to go back to it.
