Hello,
Is there anyway to reduce the UI size? On my PC the right panel takes about 1/4 to 1/3 of the screen, and I think the texts, and empty spaces between the various UI elements could be reduced.
So is there such a setting that can be modified?
Other wise, I suggest it to be a feature for future versions.
I had to change the scale factor on my display settings to get it to look correct, bit of a dirty work round. Dodgy programming by someone.
Hello @Scaramazov …! ![]()
You might already know this but the right panel can be resized. If you hover over the left edge of the panel the cursor will change to let you resize it by dragging the edge and moving it to make it bigger or smaller. It only goes down to a certain size though.
My issue is about the size of the elements within the panel. And as you said, it has a minimum width which is too big.
