I have given up on organic (Tree Auto) supports in CrealityPrint 5. There are supports with their bases positioned in mid-air (see screenshot). If you don’t look closely at the sliced model in the software, you wouldn’t notice that they are not attached to anything–they are literally floating in space. See the image below. I won’t even get into the “Manual” settings for supports, which I have not once succeeded in getting to work correctly. Their “normal” supports waste soooo much filament, too.
Has anyone else experienced these issues with organic supports?
Increase top Z distance a little to about 0.2/0.25 and decrease the tip diameter to 0.5/0.6. I use tree supports sometimes and they are easy to remove.
I have had my tree supports configured in that range for a long time. They are still difficult to remove. Mostly the small ones. Seems they put out way more branches than they need. Way too many trees also. I wish I could figure out how to do manual supports or edit the automatic supports to delete the unnecessary ones.
