How do you get/use Post Processing scrips in CP6, such as the ‘Change filament’ script in Cura’s menu, where you can have the print stop at a specific layer and change color etc.
All i find is a blank box in the slicer - are you suppose to know how to write raw g-code?
Set the layer required then right click the slider and select PAUSE. This will enter the pause command in the g-code
Bill
Thank you very much - so easy!
