Creality Print 6 Cannot select filament type
CP6 does not allow selection of any filament type for K1 Max with 0.6 or 0.8 mm nozzles except the default Hyper PLA.
I have the same problem because of the automatic filament assignment and i can not figure out, why my CFS and printer do not let me change the filament type for the print???
It took some time but here is the solution and workflow:
  • use only the filaments (top-right) you need in this printing - minus all others
  • make all your filaments you use selectable by creating user filament profiles :
    • select the bottom line of a filament ( Generic PLA …)
    • on the right of this popup thhere is the edit pencil
    • here you can edit the profile to your needs and SAVE AS
  1. filament (top-right) is used for slicing until you colored the model with other numbers. that you then can choose and select, for your print, in the printer with CFS.
You sir are an unsung hero! I was going to burst a blood vessel after selecting PETG in the CFS in that pane of filaments and it not letting me print in PETG! arghh. Too many colors were indeed added that needed removing.
Yeah, I have Creality print 7 and it is restricting me to only Creality branded filament but there is no edit icon
