Since I installed the new CrealityPrint 6, I can no longer print at 300% with the K1 Max. I can only click 125%. But that is much too slow.
Does anyone know how to set the speed back to manual? Otherwise I always have to switch on Creality-Print5 and enter 300%.
Thanks for the help
I’d suggest using that last 5.xx version until Creality gets their act together on the 6.0 version. I don’t usually use any first release of a major revision of any software for that very reason.
Hello @AbeggThomas …! ![]()
Where are you setting the speed at..?
Can you go to the network address and set the speed there…?
You can set the speed before you slice the model as well.
