Creality Print 6.x print dialog doesn't work with 4k monitor
After slicing and pressing the print button the print dialog appears. The actual print button is hidden and can’t found when using a 4k monitor with window scaling set to 150%/200%. The dialog does not allow scrolling also. The button can be found by pressing ctrl- to shrink the contents. However, it would be better to have the dialog automatically sized correctly or at least enable scrolling so the button can be seen.
Seems to be usual with Creality software, the programmers don’t seem to have worked out window resizing. The ctrl zoom is the only way at the moment.
I understand, scaling dialogs for hi-res monitors is a pain when you’re more interested in the real functionality of your app. I’m a retired Windows software developer so I really do understand. I would say though, at the very least they could enable scrolling so we could at least scroll down to the buttons. More and more people are getting 4K monitors so testing needs to be done on 2K and 4K monitors.
Especially given it worked in creality print 5. it’s actually how I still am able to print effectively. The scroll or ctrl + / - does not work for the print modal window for my shop computer. It’s a 2 k monitor and worked fine with Creality print 5.
Scroll doesn’t work for me either, and I found that ctrl+/- only worked after I clicked somewhere in the dialog. I also found that “sometimes” hitting the tab key multiple times make the buttons appear. Like you said, annoying that it used to work and now it doesn’t. New versions are supposed to get better, not worse.
