Creality print add printer parameters
Hi, I just bought 2 Flsun T1 printers to add to my Creality K2 Plus Combo (obviously still my favourite) to be able to print smaller pieces while my Creality manages the main part of the work.
I’ve seen that you could add some Flsun printers to Creality print, which is nice because the slicer is way better than the Flsun one. Unfortunately it only has older models and not the T1 or T1 pro. I tried to add another similar model (same plate, model size and settings) but it doesn’t seem to work.
What should I do to use that particular printer with my Creality Print App, right now I can see it listed in the devices but whenever I try to print with it, it says that the parameters don’t fit the selected printer.
What does it check to reach that conclusion? The printer model name, some specific settings, … ?
Thanks for your help!
