Creality Print and Sonic Pad
I have a Sonic Pad with an Ender 5 plus and an Ender 3 V3 SE connected, I can connect to the Sonic Pad through a browser no problem. Creality Print can see Sonic Pad and the printers printers when I do auto scan but it will not add them. Manually tried to add them and it still won’t add them. Am I missing something or is it a bug in Creality print? I have an Ender 3 V3 KE at home and that connects to Creality print, but is connected to a Nebula pad not a Sonic Pad. Any thoughts? Tried raising it with support but as usual all quiet on the western front.
Hi @Bonfireman and welcome to the forums.
I have not had a chance to play with the Sonic Pad as yet but it sounds to me that the slicer is only able to communicate with the Pad itself and not the printers attached to the Pad. This could be deliberate or could be an oversight in the software/firmware.
Support have been inundated with support requests lately so bare with them and they should get back to you soon. I have been told that the live chat via the Creality app or their Facebook support pages are usually the quickest for responses.
Good luck and hope you find a fix :slight_smile:
Creality Print can see the Pad and the 2 printers attached to it but can’t connect to any of them, pad or printers. Updated to the latest Sonic Pad firmware, that seems to have dropped today, and no difference there. Thankfully drag and dropping files to the web browser works just fine, so a bit of a workaround.
That’s very strange indeed. I am glad you have managed to find a workaround for now.
I do have a Sonic Pad due to be delivered soon so should hopefully be able to investigate further once it arrives.
Have noted a small thing. If you are in the web browser for the Sonic Pad you can drag and drop gcode files to the browser and then print. From the Creality Print “browser” page you can’t drag/drop, you have to click the import button instead. Seemingly not much, but just a little annoyance
I have the same problem and its now November and these people are telling me to wait for updates. I feel like throwing all and go with Bambu. Its night and day incomparison. Bambu is running circles around Creality. Its amazing how detail and trouble free with the A1.
Any updates on this? I have the same problem of:
I have to slice files, upload them to creality cloud then log in to creality cloud, wait for the file to be ready and print it from there. It would be nice to be able to print directly from Creality Print
Creality Print no longer sees the sonic pad at all and thus cannot use any printer connected to it. On the plus side Orca works perfectly with the sonic pad and all printers connected to it, use that instead.
Again some months gone.
I have the same issue but I realized something some minutes ago: If I connect the Sonic Pad via Wifi, it is realized and also the printer. If I do the same via LAN, it’s not.
I have a very bad Wifi connection, so Wifi is not an option and I need to go with LAN :frowning:
Ok, I figured out what worked.
It works to connect if the sonic pad is currently printing.
I just have one printer connected to it, so I don’t know what happens if there are multiple.
The new version of creality print now allows the sonic pad to connect to an Ender3 S1.Pro and an ender5 s1
My S1 Pro is in my workshop with no WiFi connection. I use a Lan to communicate with the sonic pad.
When setting up Creality print for the s1 pro it does not appear in the printer selection. In the device selection I can access fluidd OK. So it is back to Cura when I want to use the Si pro.
Hello Bill.b,
I have found that it now will connect to the V3SE also (though, not automatically).
As I now rarely use it (I use my Pro1 for every filament now), so when I do fire it up to check all is working, I use CP 5.1.6xxx as I am used to it and it just works.
Cheers.
