Whenever I deselect ‘auto calibration’ when sending a print, it still auto calibrates. Is this a bug? Thanks!
こんにちは。
私は本体の
・タッチパネルの印刷設定の自動PA校正・流量比校正をOFFにしてます。
・タッチパネルの校正にある3項目をOFFにしてます。
質問の意味に合っていますか?
Yes I noticed that too. I think it’s just hard wired in the gcode. For me it always checks the bed level.
From my experience, the first print after powering on the printer does automatic bed leveling, whether calibration is checked or not. After the first print it behaved normally.
I’ve just printed 4 adapters for some shelving.
When I reprint using the display I always deselect calibration, but it still carries out the calibration ![]()
I definitely think it’s a bug
In Creality Print 7.0, there is a switch in the upper-left area of the Send Print dialog where I can turn off calibration before clicking the Send button. This s a bit of a PITA because it always defaults to on, even if I’ve saved the project with if off, so I have to remember to turn it ff every time. Also: That switch is not available if I export the G-code to a USB drive, so the printer always runs a calibration in that case. (I could edit the G-code, buy why should I have to do that?)
