Creality print background after update
After most recent update to Creality print and my K2 it has changed my background on print to white behind the build plate. This is horrible and ugly, how do i change this back to black?
Mine did that too. I re-installed and it got better. and yes, I agree, the white background was just plain unusable.
@Gentoo As if the printer heard your question, my Print 7 just flipped to white background when I moved from the device to the prepare tab! The computer is under heavy load. I’m running Civ-7 in the background. It is a graphics pig. That may be a factor. All I had to do was close Print-7 and it reopened with the dark background. Seems like a stability issue.
Do you mean it switched to light mode and you used dark mode before? Ctrl+P to open preferences and check “enable dark mode”. Personally I hate dark mode but that is how to turn it on if you want it.
Yes, it is switching between light and dark mode and back again as I move between tabs or on start-up. Since it switches back and forth, it isn’t a show stopper, just an annoyance.
