Hi! I’m a newbie in Creality print and a 3D printing in total:) Could someone please help me with how to change the name of modified material (filament)? Can’t find such field. After saving it automatically creates Generic_XXX_copy (copy1, copy2, etc.) name which is useless.
Thanks in advance.
Under filament, click the down arrow.
When the filament type is shown, on the left side there is a pencil. Click that and you can edit the parameters.
Once the parameters window is open you can rename the filament.
Hi Tom! thanks for an answer, but on the third screenshot you’ve marked the search filed. It doesn’t let to rename anything.
I found out that you can set the name of the filament when saving a new one. No option to rename it after. Only to Copy with a new name.
You have to change a parameter on the right and tab out.
Then you hit save and it prompts for a file name.
Not exactly smooth
