I was printing a small cross-section part with ABS and wanted to make sure it would stay put so I increased the bed temperature from 100 to 105 for both the first layer and subsequent layers. When I ran the program I found that the display on my Ender 3 v3 KE showed a bed temp target of 105 but when I looked at the Device Target temperature in Creality Print it said 100. Interestingly when the bed came up to temperature it was controlling to 105.
ABS on a V3KE, I hope you have an enclosure, that material can be a problem on an open air bedslinger. I have noticed discrepancies in temperature between printer and what it says on Fluidd, didn’t think too much of it. I do print ABS but only on my heated enclosed printers, it is a difficult material without a controlled environment.
