When I got my printer, I read bad reviews on CR-Print, so I avoided trying it and opted for Orca instead. After reading some of the commentary on this forum, however, I decided to give it a try because I was running into some issues with Orca and flow rate adjustments.
I think the reviews I read on CR-Print were off, because I’m getting more consistently better prints off of it than I was getting before. So I’m thinking I might stick with it.
But I do have a minor question about the UI since I grew used to navigation within Orca.
The little perspective cube on top. Are you able to change a preference where that can become free moving? Or tie the perspective into a mouse click/drag type of functionality? I find that type of “pick your perspective as you need” a lot better than a defined number of set perspectives you have to manually click to see.
