Creality Print V6 Temp Calibration Tower Bugs?
First 3d printer. Friend showed me the V5 Tower Calibration. Found it in V6 - entered my temp parameters ( in the 190 to 235 band) for PLA and first message was along the lines of ’ the object is too big to print, do you want to scale it down". Upon clicking yes i get a tower with 5 layers and not the temps i entered. If you click no, the tower is about 28 steps high and goes all the way upto 345 degrees for the first layer. Have i done something wrong in the settings thanks or is this a bug?
More than likely yet another bug. Give Orca (same base software) a try for that tower, it might give you the answer that you want and has far fewer bugs.
I’m having the exact same issue as well. V5 works, V6 is totally bugged, not only the temp tower but… almost all towers.
I uninstalled V6 completely and have been working with v5 since. No major issues once all settled down
