Resin is the easiest way to get started with 3D printing, but when it comes to Creality resin 3D printer settings, you may be confused, don’t worry, we have prepared the corresponding resin settings here.
PLA-Based UV Curable Resin
| Recommended Settings |
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
20s |
20s |
50s |
60s |
60s |
70s |
30s |
| Exposure time |
2.5s |
2.8s |
2.5s |
2.8s |
2.8s |
3.2s |
2.4s |
| Turn off delay |
1s |
1s |
1s |
2s |
2s |
2s |
0s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
3mm/s |
3mm/s |
1mm/s |
5mm/s |
5mm/s |
5mm/s |
60mm/min |
| Retract speed |
3mm/s |
3mm/s |
1mm/s |
5mm/s |
5mm/s |
5mm/s |
150mm/min |
Standard Rigid Resin Plus
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
20s |
20s |
50s |
60s |
60s |
70s |
30s |
| Exposure time |
2.5s |
2.8s |
2.5s |
2.8s |
2.8s |
3.2s |
2.4s |
| Turn off delay |
1s |
1s |
1s |
2s |
2s |
2s |
0s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
3mm/s |
3mm/s |
1mm/s |
5mm/s |
5mm/s |
5mm/s |
60mm/min |
| Retract speed |
3mm/s |
3mm/s |
1mm/s |
5mm/s |
5mm/s |
5mm/s |
150mm/min |
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
20s |
20s |
40s |
40s |
40s |
50s |
30s |
| Exposure time |
2.3s |
2.5s |
2.8s |
3s |
3s |
3.2s |
3s |
| Turn off delay |
1s |
1s |
1s |
2s |
2s |
2s |
0s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
3mm/s |
3mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
60mm/min |
| Retract speed |
3mm/s |
3mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
150mm/min |
Low Odor Rigid Resin
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
20s |
20s |
40s |
40s |
40s |
50s |
30s |
| Exposure time |
2.5s |
2.8s |
2.8s |
3s |
3s |
3.2s |
3s |
| Turn off delay |
1s |
1s |
1s |
2s |
2s |
2s |
0s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
3mm/s |
3mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
60mm/min |
| Retract speed |
3mm/s |
3mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
150mm/min |
Water washable resin
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
20s |
20s |
40s |
40s |
40s |
50s |
30s |
| Exposure time |
3.2s |
3s |
2.8s |
3s |
3s |
3.2s |
3s |
| Turn off delay |
1s |
1s |
1s |
2s |
2s |
2s |
0s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
3mm/s |
3mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
60mm/min |
| Retract speed |
3mm/s |
3mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
150mm/min |
Water washable resin Plus
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
20s |
20s |
40s |
50s |
50s |
50s |
40s |
| Exposure time |
2.5s |
2s |
2.5s |
2.5s |
2.5s |
3s |
2s |
| Turn off delay |
1s |
1s |
1s |
2s |
2s |
2s |
0s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
3mm/s |
3mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
60mm/min |
| Retract speed |
3mm/s |
3mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
150mm/min |
Dental Model Resin
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
20s |
20s |
30s |
40s |
40s |
50s |
30s |
| Exposure time |
2.3s |
2.5s |
2.5s |
2.8s |
2.8s |
3.2s |
2.4s |
| Turn off delay |
1s |
1s |
3s |
3s |
3s |
3s |
3s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
1mm/s |
1mm/s |
1mm/s |
5mm/s |
5mm/s |
5mm/s |
60mm/min |
| Retract speed |
3mm/s |
3mm/s |
1mm/s |
5mm/s |
5mm/s |
5mm/s |
150mm/min |
Castable Jewelry Resin
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
65s |
60s |
65s |
65s |
65s |
60s |
50s |
| Exposure time |
5.5s |
5s |
5.5s |
5.5s |
5.5s |
5s |
4s |
| Turn off delay |
5s |
5s |
5s |
5s |
5s |
5s |
5s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
50mm/min |
| Retract speed |
1mm/s |
1mm/s |
5mm/s |
1mm/s |
1mm/s |
1mm/s |
150mm/min |
Dental Castable Resin
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
65s |
60s |
60s |
65s |
65s |
60s |
50s |
| Exposure time |
5.5s |
5s |
6.5s |
5.5s |
5.5s |
5s |
4s |
| Turn off delay |
5s |
5s |
5s |
5s |
5s |
5s |
5s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
50mm/min |
| Retract speed |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
150mm/min |
High temperature Resin
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
50s |
50s |
50s |
50s |
50s |
50s |
30s |
| Exposure time |
3.2s |
2.8s |
2.5s |
2.8s |
2.8s |
3.2s |
2.4s |
| Turn off delay |
5s |
5s |
5s |
5s |
5s |
5s |
5s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
5mm/s |
5mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
60mm/min |
| Retract speed |
5mm/s |
5mm/s |
3mm/s |
5mm/s |
5mm/s |
5mm/s |
150mm/min |
ABS Like Resin
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
20s |
20s |
40s |
40s |
40s |
50s |
30s |
| Exposure time |
2.5s |
2.8s |
3s |
3s |
3s |
3.2s |
3s |
| Turn off delay |
1s |
1s |
3s |
2s |
2s |
2s |
2s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
3mm/s |
3mm/s |
3mm/s |
1mm/s |
1mm/s |
1mm/s |
50mm/min |
| Retract speed |
3mm/s |
3mm/s |
3mm/s |
1mm/s |
1mm/s |
1mm/s |
150mm/min |
Toughness Resin
HALOT-ONE PRO |
HALOT-ONE PLUS |
HALOT-MAX |
HALOT-LITE |
HALOT-SKY |
HALOT-ONE |
LD-006 |
| Layer thickness |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
0.05mm |
| Initial exposure |
40s |
40s |
50s |
60s |
60s |
50s |
30s |
| Exposure time |
3.2s |
2.8s |
3.2s |
2.8s |
2.8s |
3.2s |
2.4s |
| Turn off delay |
1s |
1s |
3s |
3s |
3s |
3s |
3s |
| Rising height |
7mm |
7mm |
7mm |
7mm |
7mm |
7mm |
5mm |
| Motor speed |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
50mm/min |
| Retract speed |
3mm/s |
3mm/s |
1mm/s |
1mm/s |
1mm/s |
1mm/s |
150mm/min |
Tips:
- If using other brands of printers, refer to the table for printing parameters of printers with similar light intensities.
- The exposure time of transparent color is slightly longer than other color resins in the same type of resin.
Amazing!!! I was looking for something like this!! Thank you so much!
Hi!, There’s any Halot Play configuration? (or any Halot models here that can be used as a reference)
