Creality Resin 3D Printers Settings (Except MAGE series)
Resin is the easiest way to get started with 3D printing, but when it comes to Creality resin 3D printer settings, you may be confused, don’t worry, we have prepared the corresponding resin settings here.
PLA-Based UV Curable Resin
Recommended Settings HALOT-ONE PRO HALOT-ONE PLUS HALOT-MAX HALOT-LITE HALOT-SKY HALOT-ONE LD-006
Layer thickness 0.05mm 0.05mm 0.05mm 0.05mm 0.05mm 0.05mm 0.05mm
Initial exposure 20s 20s 50s 60s 60s 70s 30s
Exposure time 2.5s 2.8s 2.5s 2.8s 2.8s 3.2s 2.4s
Turn off delay 1s 1s 1s 2s 2s 2s 0s
Rising height 7mm 7mm 7mm 7mm 7mm 7mm 5mm
Motor speed 3mm/s 3mm/s 1mm/s 5mm/s 5mm/s 5mm/s 60mm/min
Retract speed 3mm/s 3mm/s 1mm/s 5mm/s 5mm/s 5mm/s 150mm/min
Standard Rigid Resin Plus
Initial exposure 20s 20s 40s 40s 40s 50s 30s
Exposure time 2.3s 2.5s 2.8s 3s 3s 3.2s 3s
Motor speed 3mm/s 3mm/s 3mm/s 5mm/s 5mm/s 5mm/s 60mm/min
Retract speed 3mm/s 3mm/s 3mm/s 5mm/s 5mm/s 5mm/s 150mm/min
Low Odor Rigid Resin
Exposure time 2.5s 2.8s 2.8s 3s 3s 3.2s 3s
Water washable resin
Exposure time 3.2s 3s 2.8s 3s 3s 3.2s 3s
Water washable resin Plus
Initial exposure 20s 20s 40s 50s 50s 50s 40s
Exposure time 2.5s 2s 2.5s 2.5s 2.5s 3s 2s
Dental Model Resin
Initial exposure 20s 20s 30s 40s 40s 50s 30s
Exposure time 2.3s 2.5s 2.5s 2.8s 2.8s 3.2s 2.4s
Turn off delay 1s 1s 3s 3s 3s 3s 3s
Motor speed 1mm/s 1mm/s 1mm/s 5mm/s 5mm/s 5mm/s 60mm/min
Castable Jewelry Resin
Initial exposure 65s 60s 65s 65s 65s 60s 50s
Exposure time 5.5s 5s 5.5s 5.5s 5.5s 5s 4s
Turn off delay 5s 5s 5s 5s 5s 5s 5s
Motor speed 1mm/s 1mm/s 1mm/s 1mm/s 1mm/s 1mm/s 50mm/min
Retract speed 1mm/s 1mm/s 5mm/s 1mm/s 1mm/s 1mm/s 150mm/min
Dental Castable Resin
Initial exposure 65s 60s 60s 65s 65s 60s 50s
Exposure time 5.5s 5s 6.5s 5.5s 5.5s 5s 4s
Retract speed 1mm/s 1mm/s 1mm/s 1mm/s 1mm/s 1mm/s 150mm/min
High temperature Resin
Initial exposure 50s 50s 50s 50s 50s 50s 30s
Exposure time 3.2s 2.8s 2.5s 2.8s 2.8s 3.2s 2.4s
Motor speed 5mm/s 5mm/s 3mm/s 5mm/s 5mm/s 5mm/s 60mm/min
Retract speed 5mm/s 5mm/s 3mm/s 5mm/s 5mm/s 5mm/s 150mm/min
ABS Like Resin
Exposure time 2.5s 2.8s 3s 3s 3s 3.2s 3s
Turn off delay 1s 1s 3s 2s 2s 2s 2s
Motor speed 3mm/s 3mm/s 3mm/s 1mm/s 1mm/s 1mm/s 50mm/min
Retract speed 3mm/s 3mm/s 3mm/s 1mm/s 1mm/s 1mm/s 150mm/min
Toughness Resin
Initial exposure 40s 40s 50s 60s 60s 50s 30s
Exposure time 3.2s 2.8s 3.2s 2.8s 2.8s 3.2s 2.4s
Retract speed 3mm/s 3mm/s 1mm/s 1mm/s 1mm/s 1mm/s 150mm/min
Tips:
  1. If using other brands of printers, refer to the table for printing parameters of printers with similar light intensities.
  2. The exposure time of transparent color is slightly longer than other color resins in the same type of resin.
What about Mage 8K???
Amazing!!! I was looking for something like this!! Thank you so much!
Hi!, There’s any Halot Play configuration? (or any Halot models here that can be used as a reference)
