Creality Scan keeps crashing on creating Mesh
Why does Creality Scan software keep crashing on attempting to create the mesh?
The error message is very generic, and pops up almost instantly on some scans when I try to create the mesh. It’s not happening on all scans, only some. I’ve only used the software for a few hours so I haven’t noticed any pattern yet. But when a scan refuses to mesh, it always refuses to mesh. I can quit and restart, and try to create the mesh - but that project will always crash immediately with the same error.
Could it be connected to the size of the point cloud? are there memory settings anywhere I can increase?
I was using the maximum 0.02mm resolution on the Optimisation settings before meshing, when I reduced the resolution to 0.05mm meshing worked.
Note my PC is a Unit - 128gb memory, RTX 4090, and 16 core Ryzen 5950 - so it’s certainly not resource constrained.
The same thing is happening to me today :frowning:
If you scan an object as large as a DSLR camera, the resolution of 0.05 is the operating limit, and the smoother should be 0.1.
Same error here.
Is there a limit of cloudpoint number the software can handle to create the mesh?
Here are the last lines of the logfile
[2025-04-08 13:38:55.144735][INFO ][46704][::0] send process msg id : OB_SCAN_MESSAGE_ID_PROJECT_IMPORT_SUCCESS
[2025-04-08 13:38:55.144735][INFO ][46704][::0] b p msg s
[2025-04-08 13:38:55.144735][INFO ][46704][::0] a p msg s
[2025-04-08 13:38:55.144735][INFO ][38612][::0] obscan_session_get_session_const_data
[2025-04-08 13:38:55.144735][INFO ][38612][::0] get session const data finished !
[2025-04-08 13:39:50.144790][INFO ][45260][::0] obscan_session_meshlization
[2025-04-08 13:39:50.144790][INFO ][40624][::0] mesh progress 0.000000
[2025-04-08 13:39:50.144790][INFO ][40624][::0] start combination meshlization !
[2025-04-08 13:39:50.144790][INFO ][40624][::0] voxel size: 0.050000
[2025-04-08 13:39:50.144790][INFO ][40624][::0] fill_hole true
[2025-04-08 13:39:50.144790][INFO ][40624][::0] is_closed false
[2025-04-08 13:39:50.144790][INFO ][40624][::0] smooth_level 0
[2025-04-08 13:39:50.144790][INFO ][40624][::0] final_triangle_num 2000000
[2025-04-08 13:39:50.144790][INFO ][40624][::0] mesh progress 0.010000
From where did you take that? How can you be sure the max resolution for a not large object as a DSLR camera is 0.05 and smoother 0.1?
I’m fancing the same problem here, looks if I capture too much details the software crashes even with lots of resources (CPU/RAM/Disk) available.
Same problem here with Creality Scan 4.3.1 in a notebook Dell G15 5511, with 32gb RAM, Nvidia RTX3050 with a Otter Lite scanner. Capture works fine, as well as fusion and aligning, but when it arrives to 80% crash, even if more than 2/3 of the RAM is free.
The issue started with the 4.3.0 version but continued after the update to 4.3.1.
The scanner firmware was also updated.
Any suggestion?
Please try to open a new project, scan something and see if meshing works in general or if it just crashes for this project.
I asked the scanner engineering team, to further investigate they also would need the log files of the crash.
