Hello,
I am building an automated turntable and scanner arm to simplify cabled scanning of small to mid-sized objects.
I’m wondering if there’s real-time output via API, socket, file or similar that I can tap into from the Creality Scan software, like FPS, distance (too far/close) and some kind of quality metric - like “percent sufficient points at this angle”. This would be to automate the RPM of the turntable, altitude and angle of the scanner arm, for example.
Thank you
@CREALITY @Optimus Can this user be helped with this question?
The scanner software is quite proprietary compared to the slicer of the 3D printer for example, there’s probably no direct way to interface it like this currently.
Thanks for the reply
A public API of some kind would be great without needing to expose proprietary software IP. Are there any public roadmaps for 3d scanner related development? Has this been flagged as a possibility? Knowing if it’s something I might look forward to vs something that’s just not going to ever happen will be really helpful for my planning!
Thanks again
