I have just received the new Creality SpacePi X4 filament dryer for review.
The X4 holds up to 4 1kg rolls of filament in two separately controlled chambers.
This is great for use with multicolor printers - k2 , Hi combo or printer from other manufactures.
In My opinion, Creality has listened to the many requests for the forum members and others in the design of this dryer.
The lid has an airtight rubber seal. when tested the humidity only increased by 2% 36 hours after the heating cycle finished. Also the X4 can be set to maintain the level
An exhaust fan in the rear of the chambers is controlled by the moisture level of the air in the chamber.
There are 4 outlets for the filament, 2 in the lid and 2 in the rear of each chamber. The outlets are designed to lock a PTEF tube that can be connected directly to the printer extruder of filament detector.
general specs:-
β Dry 4 Spools at Once: Maximize efficiency with simultaneous drying
and printing.
β Dual Independent Heating Chambers: Each chamber operates
separately for precise temperature control.
β Up to 80Β°C Heating: Ideal for high-performance filaments like PA,
PAHT, and PC.
β Active Dehumidification: Removes moisture to prevent filament
defects.
β Desiccant Regeneration: Self-regenerating system for hassle-free
operation.
β Energy-Efficient Modes: Choose between single or dual chamber
drying.
β Smart UI Touch Screen: Customize settings with an intuitive
interface.
The touch screen is very responsive and setting up is Strate forward.
Below is my you tube review. I am not a you tuber and do not have the equipment to produce studio quality videos so please forgive me for the quality of the video.
I find that the SpavePi X4 is an excellent dryer and a great improvement over other dryers available.
Bill
