Creality SparkX i7 + CFS Lite color swap error TR2963 (triple cut then fails, manual unload works fine)
Hey everyone, so I recently got the Creality SparkX i7 with the CFS Lite combo and honestly for single color prints it has been amazing. Changing colors between different projects also works completely fine.
The main issue I am running into is doing multi color prints on the same model. Right now I am just testing with black and white PLA.
During a color swap, the head goes to the far left side and cuts once, moves a bit to the right and cuts a second time, then moves again and cuts a third time. After that third cut, the CFS tries to pull the filament back up the tube, fails to retract it all the way, and throws a cutter jam error followed by TR2963 (filament jammed or broken).
Here is the weird part. If I hit OK and then click proceed on the screen, it extrudes the waste, retracts the old roll, loads the new color, and keeps printing like nothing happened. But it wastes a ton of filament doing that every single time.
Things I have already checked:
  1. I took the whole extruder apart to see if something was jammed inside. The blade cuts fine and the cutter lever snaps back normally. The only thing I noticed is the cut piece of filament was just sitting low in the throat because it failed to pull up.
  2. Loading and unloading manually works 100 percent of the time. When I do it manually, it cuts on the left, but then it glides over to the right side above the purge chute to retract the filament, so it never struggles there. The mid print error only happens when it tries to pull while parked on the far left.
  3. I tried turning the CFS sideways and even printed a top mount support bracket to change the tube path, but I still get the exact same error on mid print swaps.
Has anyone else dealt with this triple cut failure on the SparkX i7? Or is there a physical fix for this left side issue?
Appreciate any advice!
I have the same problem, but in my case, even the manual switch doesn't work. Did you manage to solve it?
