Creality V6 - Quit should mean abandon
When your using V6 you have the ability to:-
1 Save the file - overwrite
2 Save as - give new name
3 Quit - V6 overwrites existing file
However quitting saves the file (similar to Bambu studio). I find this annoying. In my mind quit means abandon.
It is normal in software programming to either abandon a file where you are not happy with the parameters OR when you load a file up and intend to play/test then you immediately save as so the original stays intact.
With so many parameters in a model I am sure people will try different parameters and without realising, when reloading next time, think that’s different.
At the moment you have no way of abandoning your work and starting again
Currently there is a good chance you will mess up the next print :frowning:
Hello Mrburns,
I agree with you wholeheartedly; Quit should be " Forget it"
That, is a very disturbing method they have taken.
Cheers.
