What’s going on with the latest version of CrealityPrint_6.0.4.1793_Release? It no longer recognizes the printer on the network. Is this a software bug, or is there a firmware update coming for the printer to make everything work properly?
Mine recognised the printer immediately; I’m connected with ethernet.
In the past you had to sometimes delete printer and search again. But for the update was smooth
I have the same problem, did you find any solution?
I have issues with the v6.0.4 release, I reported here: [Creality Print V6] The current printer does not match the preset settings of the selected printer - #8 by Taomyn
I uploaded the sliced project I was trying to make instead direct start print, then loaded it on the printer. It seemed to print ok, but this is a pain.
I found the solution: I changed the software language (French to English for me), after a restart, everything is ok. Then I changed the software language (English to French)
same problem here, with Ender 3 v3 plus
I tried that twice, and it made no difference to my installation, I still have the same message
Version 6.04.1793 - The good - 6.0 works fantastic with the K2 Plus CFS, I love the color paint feature. This shoudl be an advertised feature as I stumbled upon the capability. The ugly, found 3 bugs in the newly released 6.04.1793:
1 - Big Problem. App does not register that I logged into CrealityCloud, and not allow me to send file to the CrealityCloud, error says I am not logged in, When clicking upper right cloud icon to login, it does login and go to my uploads. I can upload FROM the cloud, just not send file from CrealityPrint 6. FWIW, I am a premium account holder.
2 - I cannot add my Sonic Pad printer, even though its registered on Creative Cloud. I select + ADD, select Creality and Putting IP … none found. Filter is set to ALL, and even set to sonic only it still does not find it. This worked in 5.0, with teh sonic pad selection icon. Selecting GENERIC and putting in IP does find it however you get the Fluidd interface. Only way to send print is by uploading STL to Cloud, cloud slice and send to registered printer ( Ender 3 V3 SE) attached to the Sonic Pad. This is a BIG problem.
3. Odd behavior - K2 Plus CFS Filament selection maintains with all SELECTED printers, not just spool expected on other CC registered Creality printers.
Absolutely will not see my K2 on the wifi network.
Revert to older software without changing anything else and it sees the printer just fine. K2+ with CFS.
[quote=“Taomyn, post:4, topic:32783”]
[[Creality Print V6] The current printer does not match the preset settings of the selected printer ](https://forum.creality.com/t/creality-print-v6-the-current-printer-does-not-match-the-preset- [[Creality Print V6] The current printer does not match the preset settings of the selected printer ](https://forum.creality.com/t/creality-print-v6-the-current-printer-does-not-match-the-preset-settings-of-the-selected-printer.
I can’t seem to overcome this message, so I tried Orca slicer and that runs perfect and you can sent slices direct to your printer. So give it a go.
Something I noticed while trying to get v6.0.4 working, is that CrealityPrint annoyingly relies on Microsoft’s WebView2 and if that’s not working properly will kill all access to the Internet and even directly to the printer.
I recalled seeing Windows prompt to allow something through when I started CrealityPrint which I accidentally cancelled and found that it would no longer show me CrealityCloud or the printer’s camera. After removing and reinstalling WebView2 again with CrealityPrint closed, that all started working - didn’t fix the stupid message in printing unfortunately.
This solution seems to work for me. I had the setting in Portuguese, and I switched it to English. When I checked the DEVICE tab, the printer already appeared; before, I only saw a black window with no indication.
I found similar issue and i did fix it by swap the languages and the revert back.
However all my Fillament presets did erased, so I had to input again the parameters from an old backup, only a few settings where missing. Suggest to export the settings first before upgrading and swith languages
