Hello,
I have been using the device for a month. There were no problems. I wanted to print flow calibration in Crealty 6.0, which is different from normal. Now the printer is turning on, I can see it on the network via the PC, but I cannot do anything. The axes do not move, the extruder does not work, there is no camera connection, I reset it to factory settings but it did not help.
Do you still have the older 5.1.x version that worked? Does it work with the printer now? I think that v6 is a little buggy. Perhaps try the latest Orca?
Same problem here, right after switching to CP6, now the printer is completely broken, many other functions also do not work besides printing.
I got it to work again and get back on the network by going to fluidd in my browser, and then i deleted all past jobs and then uploaded a stl file and printing it from there, then everything on the printer went back to normal. i will need to try to print from CP6 again though.
It didn’t happen again in the old version
The printing function also does not work. The device does not even run ready-made files on USB.
I cleared the print order from http://192.168.1.x:4408 and it worked. thanks
