Hi all,
I am a fresh owner of Hi Combo. The set-up and first couple of prints went great. Then I start to get an error CX2573 at starting of any new print and at self-check. I checked for any obstructions. I check the connections and everything seems to be fine. I greased all the guide rails. I reset the to printer to the factory settings. The problem still apprears. It looks like the movements of the header are limited or maybe even impossible. At every self-check it looks the same: the head moves an inch up, as it is trying to go to z-axis home position, and then stops and reports error CX2573.
I don’t know what more I could test. Is there maybe a way to check if motor is working correctly? Because I am starting to think that it has an issue.
I will be glad for every advice or suggestion what else I could check.
In detailed log I found a message “no trigger on x after full movement”, but I still don’t know where the problem is ![]()
Most likely, there is no signal from the limit switch on the X axis. The limit switch is located on the left of the print head. Limit switches are needed to determine the location of the absolute zero coordinates of the print head. For this purpose, parking on three axes occurs first, and only then the print head can move along the coordinates specified by the computer.
I checked this limit switch and it works fine. I tested it with multimeter and also I triggered it manually by homing process which caused this process to continue. But the print head didn’t move in x-axis, which probably means that there something wrong with x-axis motor. I tried to take this motor out, so I could test if works without any resistance, but it is impossible without taking off the belt. Or is there maybe a different way to do it?
watch a youtube video on replacing the x-axis rail guide. You will need to remove the print head. And you will have access to the plate that closes the ends of the belt.
Yes, I did it. I couldn’t find there anything unusual
The belt seams to be correct. I still think there is a problem with x-motor.
я писал как снять ремень, чтобы можно было снять мотор. У вас проблема по мотору либо плате управления этим мотором, либо с контактами проводов. Тут уже не обойтись без мультиметра.
Google Translate:
I wrote how to remove the belt so that you could remove the motor. You have a problem with the motor or the control board of this motor, or with the wire contacts. You can’t do without a multimeter here.
Although my advice seems a little silly, check the camera cover, it should be located right in the lower front corner. If the fault persists, return to firmware version 0.38
Not sure what this has to do with anything but I moved the cover back over the screen and I am no longer having the x-axis issue. As silly as your advice seemed it worked thank you so much
I ran into this Problem 2 days ago after a 5-hour printing session the day before. No problem with the Limit switch or the x-axis movement, but some accumulated residue on the nozzle, preventing the Print head from reaching all te nway to the part rejection unit, Since there was this error, the printer did’t heaut up (which would have solved the problem) and i had to break away thac lump of waste manually. Lesson learned…
That was exactly my problem. Thanks a lot!
I manually heated nozzle by soldering iron and then clean it up with provided wire and brass brush
Clearing the nozzle also fixed my issue. Bought cleaining brush right after that ![]()
Did you figure out what the issue was?
Also had this issue - I found that after a long multicolor painted print, a mess of melted / then solidified filament had stuck to the poop ejector. It was stuck on so hard I had to get a heat gun to gently melt it and pull it off with pliers - problem solved.
Your “silly advise” just saved m from wanting to return this thing after just pulling it out of the box. Thank you kind human!
Hello, I’m also experiencing the same issue. Initially, it was a different problem, but after replacing the motherboard under warranty, this error started to occur. My printer was only 20 days old and had at most 7 prints completed.
Has anyone managed to fix it? I’m currently waiting for Creality support to provide the next steps, since the printer is still very new. In any case, if anyone has any suggestions, I tried enabling/opening the camera, but it didn’t work.
The printer’s X-axis (print head carriage) does not move at all.
Hi all, sorry for late answer. In my case the problem was x-acis motor, which needed to be replaced. As I did it, everything works fine for last couple of months.
Hi! I have the same issue with my Creality Hi.
Could you please tell me:
- What is the part number or model of the X-axis motor you replaced?
- Where did you buy it?
- Do you have a link to the motor?
- Is there a video or guide showing how to replace the X-axis motor?
I would really appreciate your help. Thank you!
Hi, sorry but I don’t have many good news for you. The x-axis motor was sent to me by the store where I bought my printer: 3dprima.com, so I don’t have a link or a serial number.
I can’t provide you a guide neither as I was unable to find any. I did the replacement on my own with it.
Actually 3d printer is a kind of self maintenance tool, in my opinion. If you want to use it regularly, you just need to know how it works and what are potential sources of issues. It brought me a lot of satisfaction to replace this motor on my own. Now I know that I am a true owner of my printer!
