DeskPrint Studio for Creality Hi — smartphone timelapses, Aurora interface, OrcaSlicer integration and more
Título:
Hi everyone!
I’m developing DeskPrint Studio, an independent ecosystem currently focused on the Creality Hi. It brings together a desktop application, a new printer interface called Aurora, and a mobile Companion app.
The Hi version is approaching its first release, and I’d like to share some real demonstrations of what I’ve been working on.
Timelapses using your phone
One of the main features is using phones as timelapse cameras through the Companion app. You can reuse a phone you already own, position it where you want, and capture your print from a different angle.
The capture system supports multiple participating devices, including phones and webcams connected to the desktop. Camera settings depend on the capabilities of each device, with quick and adaptive capture modes.
The system coordinates capture with the printer’s movements and waits for exposure confirmation within a limited time budget. Image processing and transfer continue in the background. If a capture fails or times out, printing can continue.
The timelapse below was produced by the system using a Samsung Galaxy S10+.
Aurora: a new interface on the printer
Aurora gives the Hi a different touchscreen experience, with redesigned navigation, material controls, camera settings and an animated mascot.
The mascot accompanies the interface and printing experience. On the desktop, it can also follow the active printing path in the G-code visualization.
The interface includes temperature, fan and speed controls, axis movement, homing and filament operations, with contextual messages and guards appropriate to each action.
DeskPrint Studio brings its printer management interface into OrcaSlicer’s Device tab and provides a filament synchronization workflow.
The integration reads the printer’s material inventory, preserving the association between CFS compartments and their materials. It also handles the external spool when no CFS is connected.
This integration uses a compatibility-specific patch, so supported Orca versions matter. It is an independent integration, not an official OrcaSlicer feature.
More precise filament colors and clearer CFS controls
The filament interface provides finer color selection and can represent a material with up to four colors, useful for identifying multicolored or gradient spools.
CFS compartments are shown visually, with selectable spools and humidity/temperature information when the printer supplies it.
These colors describe the material’s appearance. They do not turn one spool into several materials, and what can be synchronized depends on the slicer and firmware.
Separate camera, capture and lighting controls
The camera controls let you manage camera operation and illumination separately, including disabling the camera through the interface.
Participation in timelapse capture is also a separate choice. The integrated camera can be included in the coordinated capture system without requiring every external camera to depend on it.
Exclude an object without cancelling the entire print
For compatible, object-labelled prints, you can exclude an individual object after printing has started. If one part fails, this can help save the remaining objects on the bed.
Object exclusion already exists in Klipper/Fluidd workflows; the goal here is to make it accessible within the Hi’s Studio experience.
Timelapse processing and a print library
The desktop application organizes captures by print session, printer and capture device. Photos from different cameras retain their own sequences.
The processing tools include frame rate, output resolution, rotation and playback-speed settings, a processing queue and optional automatic processing. Frame interpolation is available when its required runtime and hardware are supported.
The Library groups photos and videos with the corresponding print and G-code thumbnail. Original captures are retained until the user explicitly chooses to remove them.
Custom sounds and a music composer
The printer’s buzzer can do more than standard beeps. DeskPrint Studio includes MIDI conversion, playback tools and a monophonic score editor for creating melodies.
Compositions can be named, saved, reopened, edited and assigned to supported printer events. The composer includes notes, rests, tempo changes and musical articulation, with preview options on the computer or printer.
Multiple printers and devices
The desktop application is designed to manage multiple printers and capture devices without a fixed printer-count limit. Devices retain stable internal identities while displaying the names chosen by the user.
There are also tools for installing and maintaining the printer modules, checking for updates and managing compatible slicer patches. Maintenance actions remain subject to device identity, connection and printer-state checks.
Works alongside the Creality ecosystem
DeskPrint Studio is designed to work alongside the existing Creality services. Creality Print remains part of the workflow, and OrcaSlicer offers another route through the integration.
The latest capture work coordinates the timelapse triggers used by both slicers, while preserving exposure confirmation for participating devices.
Current status and next steps
The videos show real use on my current Hi setup. Some newer functions and combinations are still undergoing validation, and I’m preparing the distribution package and documentation.
My next goal is to develop and validate support for K1 and K2. I also want to investigate the SPARKX i7/i8, but I’m not promising compatibility before establishing what is technically possible.
Internet-based remote access and AI-assisted print-failure detection are future development goals.
I’d love to hear from other Hi owners: which feature would you most like to see demonstrated in detail?
DeskPrint Studio is an independent project and is not officially affiliated with Creality or OrcaSlicer.
