do i need a honeycomb base for my creality power pro 2 laser printer with slats
If your cutting I would suggest a honeycomb but not 100% necessary . If just engraving you don’t need.
A honeycomb has a finer contact surface, the upper edges of the rods are slightly wider so that a small amount of soiling can still occur on the back, but it is much better than cutting on a solid surface. So you don’t need it but if you want even cleaner back sides of cut pieces it could be helpful.
Many thanks ![]()
