I recently got a Creality K1 Max and am looking for advice on the optimal settings for getting the best print quality and performance out of it. If anyone has experience with this printer, could you share the settings you use, including things like print speed, temperature, bed levelling, and filament types? Any tips or tricks would also be greatly appreciated!
Thanks in advance for your help!
Any filament in senses is good quality as long as used correctly
temps differentiate depending on filament but it’s best to use either what’s on the box or give it a quick google to see what temps it should be at. For settings. It’s best to get a test piece going (Maybe just a medium square for example) and play around with the settings yourself! Different jobs might need different settings. Learning what everything does bit by bit will help in the long run. I use a V3 NEO so I can’t do much help at giving you a default “good” print setting. But, hopefully someone comes in here clutch
