Does gcode work on all 3d printers
does gcode work on all 3d printers
Hello c1512,
Gcode is not universal and therefore can not run correctly on EVERY fdm (Fused Deposition Modeling) printer.
The code can vary due to the bed size it was created for or the printers operating system.
Is there a particular gcode file you are trying to run, but won’t ?
Cheers.
hi I’ve got a weefun tina just bought an ender3 S1 and was wondering if i could use the gcode on both
No, you need to slice oject(s) specificly for the printer you are going to use, unless they share almost all attributes.
thanks for the advice
Hello c1512,
As long as you were to stand there and watch the print go through to finish (not a five hour job),
if it prints ok … then there should not be a problem.
In my thinking, as long as the printing area of both printers is the same there is a good chance of it working ok.
Trial and error (but don’t walk away the first time).
Cheers.
thanks will give it a try
