Download G Code Failed
Does anyone have any idea why when I use the wifi to send a print to my printer i get a download error. It says download failed. I can nor figure out why. It use to work and now it does not.
Thanks
Same problem here. When I try to print over Wi-Fi, I get “Download failed” with error code XD0114. It used to work fine and then just stopped. Has anyone found a fix?
im having the same issue it wont print with my laptop but will print with my phone which is weird in my opinion.
I can’t print either
It says Download g-code failed
Printer is now a heavy brick.
The more I upgrade the more i got more and more errors
Update : juste relaunched Crelaity print and problem gone.
I still can’t print with wifi. I need to use a USB stick to transfer files. It worked fine and now nothing. This sucks
Which firmware version is on the printer and which slicer you use? Is it the mobile app or on a laptop? And which version is the slicer app?
i have same issue
Same issue here when I send a print using Creality cloud. Using local network works fine. But I’m not able to start any print when I’m not on the local network.
Having the same issue with STL file it uploads then the download fails and no error code is given. What the fuck? An $800 dud.
If you’re on the latest version of Creality Print, try an older one. I couldn’t print after updating to 7.3 with similar errors. Went back to 7.2 and no problems. There are no improvements for K2 in the new versions anyway.
I’m sorry but printers don’t use STL files. Slicers use STL files and printers use GCODE.
What does the Web dashboard of the printer show?
How do I go back to 7.2
