E-Sun ASA keeps failing
Hi everyone,
I’m experiencing problems when printing the Bento Box V2.0. After about 2 to 5 mm of height, the walls start to come loose from the print bed.
Here’s what I’ve tried so far:
  • Using 3DLAC as an adhesive
  • First layer at 250°C, subsequent layers at 240°C (also tested at 260°C)
  • Bed temperature at 100°C (also tested at 110°C)
  • Various print speeds
  • Heated the bed for 20–30 minutes before starting
  • Inside print temperature between 38°C and 52°C
  • Tried both Orca slicer and Creality slicer 6.2 with standard settings and some adjustments
Despite these efforts, the adhesion issues persist, and I also notice the corners are curling upwards.
Questions:
  • Is 3DLAC not suitable for ASA? Should I try a different adhesive?
  • Are there specific settings or techniques I should adjust to improve adhesion and prevent warping?
  • Could the temperature settings or print environment be contributing to this problem?
Any advice or suggestions would be greatly appreciated. Thanks in advance!
Hey Fifi! :wave:
Sometimes I have similar issues, but on my Creality Ender 3 v3 SE, and I use PLA and TPU. If you haven’t already try thouroughly cleaning the print plate. Here’s a potentially helpful link:
Bed Plate cleaning
Hope this helps! :smiley:
With PLA and PETG I don’t have problems with the adhesion. I clean my print plate each time thouroughly, mostly with Isopropyl alcohol, now I know by your link that window cleaner also helps. I think I will not clean my print plate everytime with the alcohol but will use the window cleaner as basic cleaner. Thanks for helping solving the problem and adding the info page.
Yeah, no problem! Happy to help! :grin:
I had similar issues with E-Sun ASA until I tweaked my slicer settings. Switching to Creality Print helped a lot — better support and temperature control. Try increasing the bed temp and use an enclosure if you can. That combo worked for me!
