Hi
Does anyone know how to use either the Text tool or the emboss tool?
Using the emboss tool I find the lettering slides under the model, which means to print it I have to mirror it first???. I’ve tried clicking on edit text and just occasionally I get a complete menu that has negative, parts and modify within. But as I said that’s very rare.
I tried the text tool as well but that seems to have it’s own limitations but it does seem to sit on the top of the model.
Many thanks for any help. Confused
Havent triedit with creality print but
if you have windows and 3d builder then you can emboss with that and save it as an stl file
Thankyou for that. I had never heard of it and my win 10 didn’t have it. It seems to have been deleted from the microsoft store so you have to enter a back way to get it. Which I found online. It seems a lot more user friendly than some of the others.
However I’ll check it out more deeply. thanks Again
Must thank you again Andrewson. 3D builder just works. I’ve tried a number of different
Builders and would rank this the best and the easiest
Great you could get it! It also works well for cleaning up meshes pre print.
Tinkercad will do it. They teach it to 3rd graders…so…I can do it!
