Hello, I just assembled the Ender 3 printer and when I use the auto home setting not all the axis are in position 0. Is that correct?
Once you print something, the Ender 3 will perform it’s own test and you’ll find that everything will run fine.
I must admit that, when I first turned on my KE, I was a little concerned by the same thing but it runs perfectly once it’s printing.
Hope this helps
You are right. Printer is working fine. Thanks
