Hi there,
after some pause from printing (made some small prints a year ago) and installing new PETG I’ve managed to successfully print.
On the second print, I’ve got blockage. I’ve replaced the nozzle, cleared the tube, checked that it is cleaned by pushing it through.
Then, I’ve tried to print PLA benchy. It was fine till the “roof” it began stringy and didn’t stuck.
This was “original gcode”.
I’ve changed then again to PETG and tried multiple thing in slicer:
- vent to max 20 %
- temp to 240 °C
- bed 80 °C
- retraction 5.5
Printer was working fine before and had occasional bed adhesion issues. Now glass adhesion is good (clean surface, leveled bed, z offset was a little bit low I’ve changed this).
I though it was a too-strong force on the extrusion lever (spring tension screw). I’ve losen it.
After print fails i can see that end of the filament is buldged and some biting marks from extruder.
When next print starts there si no issue (filament inserted) so I rule out that it is clog in the tube but the next print fails on level 2 or 3. It starts to look like the lines are “thinner” and it doesn’t stick so the extrusion stops.
I’m not sure is it hardware issue or a slicer issue or a combination.
Does someone have an idea what I should try next?
