Hi Everyone, I feel foolish for even starting this topic as I see half a dozen other similar ones, but after going through all of them, nothing seems to work. I’ve installed the sprite direct extruder pro kit onto my Ender 3 Neo because my stock one kept throwing temp errors. After taking it apart during the installation, I think it’s because filament got jammed up inside of it, but that ship has sailed with the new extruder.
No matter what I do, I can’t get the build area and offsets calibrated. I upgraded to the latest stock firmware. I tried to use the Mcodes for updating the offset but nothing worked and all of my builds are off center.
I know folks are probably tired of seeing these requests, but I’m desperate as I can’t use my printer the way it is.
From what I can tell, the only way to get my nozzle to even start at the home space, is by manually moving it to X-27 (which is as far as it can go because of the limit switch) and Y10 (this would allow it to get past the build plate clips if it actually printed out that far. Whenever I tried to use M206 for this, it just travelled all the way to the far end of the build space instead of the bottom left.
I had no issue updating the E steps, but I can’t for the life of me figure out how to properly calibrate my print area and offsets.
If anyone could help, I would be grateful.
