Howdy, I am once again back because I’m awfull at anything software/firmware side. I’m currently experiencing an issue with height-mapping my build plate. The first issue I encountered was the hot end slamming into the build plate on the very first calibration point (which has now been resolved using this video, https://youtu.be/5vmjBXvY6BA?si=WE9TNFlROmCELXda)
With that issue out of the way, my new slice of hell is this error whenever I try to go through height map calibration (it will probe the first row at the front of the build plate just fine, then will post this < {"code":"key243","msg":"Move out of range: 270.000 47.000 5.000 [0.000]", "values":[270.000, 47.000, 5.000, 0.000]>. I’m not sure if I need to go to the next step of the video (time stamp of 13:00), and if so, would the difference in hot end assembly’s affect how I would go about the process?
